Reset electricity consumption memory on Fibaro RGBW
Everything about Z-Wave radio devices with eedomus
Messagepar davsdom » 06 Août 2020 11:58
dear all
any idea to reset the electricity consumption memory from eedomus controller.
I'm trying to avoid reseting the whole device. thanks in advance.
Davs
davsdom
Re: Reset electricity consumption memory on Fibaro RGBW
Messagepar thrymartin » 06 Août 2020 19:41
perif: config/config z-wave/meter reset
(set expert mode before)
thrymartin
Messagepar davsdom » 06 Août 2020 19:49
THANKS for your answer. I did it, but it seems it didn't solve the issue. several dimmers show weird data in consumption since 10 months ago...
any other idea?? thanks!
davsdom
Messagepar thrymartin » 07 Août 2020 08:32
on fibaro : config / z-wave
command_class_meter
meter_reset
send
have you seen:
transmit_complete_OK
thrymartin
Messagepar davsdom » 07 Août 2020 08:39
yes.
METER_RESET Ejecutado TRANSMIT_COMPLETE_OK
Seems the memory was deleted , but it seems it's not been updated !-(
now the fibaro RGBW shows 2.7W from 13 hours ago...but if I power off the device, it doen't show 0 W....it's fixed to 13 hours ago when I deleted the memory.
checked these other settings and polling enabled
N° du paramètre=[44] Contestado Number=[44] Size=[2] Value=[30] Power load reporting frequency
N° du paramètre=[45] Contestado Number=[45] Size=[1] Value=[10] Reporting changes in energy consumed by controlled devices
maybe it's a firmare problem? I have the same issue with all fibaro RGBW I have...other devices are ok with power consupmtion reports...
any option to update fibaro device firmware without fibaro home center???
thanks for your help!
davsdom
Messagepar thrymartin » 09 Août 2020 06:21
OK,
Apparently the question has already been asked and it looks like the meter_reset command is not working.
The module must be completely reset
(google translate)
Resetting the FIBARO RGBW Controller does not mean that it has been deleted from the memory of the Z-Wave network controller. It is best to remove the FIBARO RGBW Controller from the Z-Wave network controller memory before performing the reset procedure.
Disconnect the power supply from the device
Press and hold button B
Connect power to the device while holding button B
Release button B
Channel B (blue) will engage
thrymartin
Retour vers Z-Wave devices
