Reset electricity consumption memory on Fibaro RGBW
Everything about Z-Wave radio devices with eedomus
Messagepar davsdom » 06 Août 2020 11:58
dear all
any idea to reset the electricity consumption memory from eedomus controller.
I'm trying to avoid reseting the whole device. thanks in advance.
Davs
davsdom
Re: Reset electricity consumption memory on Fibaro RGBW
Messagepar davsdom » 06 Août 2020 19:49
THANKS for your answer. I did it, but it seems it didn't solve the issue. several dimmers show weird data in consumption since 10 months ago...
any other idea?? thanks!
davsdom
Messagepar davsdom » 07 Août 2020 08:39
yes.
METER_RESET Ejecutado TRANSMIT_COMPLETE_OK
Seems the memory was deleted , but it seems it's not been updated !-(
now the fibaro RGBW shows 2.7W from 13 hours ago...but if I power off the device, it doen't show 0 W....it's fixed to 13 hours ago when I deleted the memory.
checked these other settings and polling enabled
N° du paramètre=[44] Contestado Number=[44] Size=[2] Value=[30] Power load reporting frequency
N° du paramètre=[45] Contestado Number=[45] Size=[1] Value=[10] Reporting changes in energy consumed by controlled devices
maybe it's a firmare problem? I have the same issue with all fibaro RGBW I have...other devices are ok with power consupmtion reports...
any option to update fibaro device firmware without fibaro home center???
thanks for your help!
davsdom
Retour vers Z-Wave devices
