Module Exclusion/Reset (Removing from Z-Wave network)By this function all parameters of the module are set to default values and own ID is deletedIf service button S is pressed more than 2 and less than 6 seconds (or if push button I1 is pressed three times within 3s) module is excluded, but configuration parameters are not set to default values.
- Connect module to power supply
- bring module within maximum 1 meter (3 feet) of the main controller,
- enable add/remove mode on main controller
- press service button S for more than 6 second or
- press push button I1five times within 3s (5 times change switch state within 3 seconds) in the first 60 seconds after the module is connected to the power supply.
