j'accepte mais si je relance la même url de test, ça me redemande encore la validation sur la TV.
je tourne en rond donc j'ai peut être zappé un paramètre
voici l'url que je tape pour test:
http://192.168.x.xx/script/?exec=ancien ... KEY_SOURCE
$_REQUEST["key"] = getArg('command');
$key = "KEY_" . $_REQUEST["key"];
$tv_ip_or_mac = getArg('tv_ip_or_mac');
$tv_ip = sdk_get_ip_from_ip_or_mac($tv_ip_or_mac);
$eedomus_mac = getArg('eedomus_mac');
$eedomus_ip = sdk_get_ip_from_ip_or_mac($eedomus_mac);
$command = getArg('command');
$appstring = "iphone..iapp.samsung"; //What the iPhone app reports
$tvappstring = "iphone.UD40D6310.iapp.samsung"; //Might need changing to match your TV type
$remotename = "eedomus"; //What gets reported when it asks for permission/also shows in General->Wireless Remote Control menu
$sock = socket_create(AF_INET, SOCK_STREAM, SOL_TCP);
$result = socket_connect($sock, $tv_ip, '55000');
if( $result === false)
die ("Could not create socket");
$ipencoded = base64_encode($eedomus_ip);
$macencoded = base64_encode($eedomus_mac);
$remotenameencoded = base64_encode($remotename);
$messagepart1 = chr(0x64) . chr(0x00) . chr(strlen($ipencoded)) . chr(0x00) . $ipencoded . chr(strlen($macencoded)) . chr(0x00) . $macencoded . chr(strlen($remotenameencoded)) . chr(0x00) . $remotenameencoded;
$part1 = chr(0x00) . chr(strlen($appstring)) . chr(0x00) . $appstring . chr(strlen($messagepart1)) . chr(0x00) . $messagepart1;
socket_write($sock, $part1, strlen($part1));
echo $part1;
echo "\n";
$messagepart2 = chr(0xc8) . chr(0x00);
$part2 = chr(0x00) . chr(strlen($appstring)) . chr(0x00) . $appstring . chr(strlen($messagepart2)) . chr(0x00) . $messagepart2;
socket_write($sock, $part2, strlen($part2));
echo $part2;
echo "\n";
//Preceding sections all first time only
if (!empty($command))
//Send remote key
$key = base64_encode($command);
$messagepart3 = chr(0x00) . chr(0x00) . chr(0x00) . chr(strlen($key)) . chr(0x00) . $key;
$part3 = chr(0x00) . chr(strlen($tvappstring)) . chr(0x00) . $tvappstring . chr(strlen($messagepart3)) . chr(0x00) . $messagepart3;
socket_write($sock,$part3,strlen($part3));
echo $part3;
echo "\n";
socket_close($sock);
echo "\n\n";
http://192.168.xxx.xxx/script/?exec=ancien.php&tv_ip_or_mac=F8:04:2E:FA:XX:XX&eedomus_mac=00:60:6E:33:XX:XX&command=KEY_SOURCE
hornet49 a écrit:Ok je m'y colle, juste une petite question, est il possible d'optimisé le scripte en évitant de demander l'adresse MAC de l'EEDOMUS ? on doit pouvoir la trouver ou la déduire sans la demander dans un champs je pense ?
$command = base64_encode(getArg('command'));
$description = base64_encode('eedomus remote controller');
$id = base64_encode('eedomus');
$remotename = base64_encode('eedomus');
$payload = chr(0x64) . chr(0x00);
$payload .= chr(strlen($description)) . chr(0x00) . $description;
$payload .= chr(strlen($id)) . chr(0x00) . $id;
$payload .= chr(strlen($remotename)) . chr(0x00) . $remotename;
$packet = chr(0x00) . chr(0x00) . chr(0x00) . chr(strlen($payload)) . chr(0x00) . $payload;
socket_write($sock, $packet, strlen($packet));
//Send remote key
$payload = chr(0x00) . chr(0x00) . chr(0x00) . chr(strlen($command)) . chr(0x00) . $command;
socket_write($sock,$packet,strlen($packet));
http://192.168.xxx.xxx/script/?exec=ancien.php&tv_ip_or_mac=F8:04:2E:FA:XX:XX&command=KEY_SOURCE
