Multiroom Raspberry Max2play et diffusion UPnP
et assistants vocaux
Re: Multiroom Raspberry Max2play et diffusion UPnP
Messagepar fred54 » 06 Nov 2016 15:43
Si je remplace 9000 par 9002 cela me donne ça en test sur l'eedomus
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
"http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<title>Platine Squeezebox max2play </title>
<link rel="stylesheet" href="/slimserver.css" type="text/css">
<link rel="stylesheet" href="/skin.css" type="text/css">
</head>
<body bgcolor="#FFFFFF">
<h3>Platine Squeezebox max2play</h3>
<div id="playingStatus">
En arrêt à
</div>
<div class="playingSong"><a href="/songinfo.html?item=&player=b8%3A27%3Aeb%3A47%3A49%3Af8" target="browser"></a>
Rien
</div>
<hr><a href="status.html?p0=playlist&p1=jump&p2=-1&player=b8%3A27%3Aeb%3A47%3A49%3Af8">Précédent</a>
<a href="status.html?p0=playlist&p1=jump&p2=%2b1&player=b8%3A27%3Aeb%3A47%3A49%3Af8">Ignorer</a>
<a href="status.html?p0=play&player=b8%3A27%3Aeb%3A47%3A49%3Af8">Lecture</a>
<a href="status.html?p0=pause&player=b8%3A27%3Aeb%3A47%3A49%3Af8">Pause</a>
<b>Arrêt</b>
<br>Répéter :
<a href="status.html?p0=playlist&p1=repeat&p2=0&player=b8%3A27%3Aeb%3A47%3A49%3Af8&start=0">éteint</a>/<a href="status.html?p0=playlist&p1=repeat&p2=1&player=b8%3A27%3Aeb%3A47%3A49%3Af8&start=0">un</a>/<b>tous</b>
<br>Mélanger :
<b>éteint</b>/<a href="status.html?p0=playlist&p1=shuffle&p2=1&player=b8%3A27%3Aeb%3A47%3A49%3Af8&start=0">morceaux</a>/<a href="status.html?p0=playlist&p1=shuffle&p2=2&player=b8%3A27%3Aeb%3A47%3A49%3Af8&start=0">albums</a>
<br>
Platine :
<b>allumé</b>/<a
target="_top" href="index.html?player=b8%3A27%3Aeb%3A47%3A49%3Af8&p0=power&p1=0">éteint</a>
<br><br>
Volume :
<a href="status.html?p0=mixer&p1=volume&p2=0&player=b8%3A27%3Aeb%3A47%3A49%3Af8&start=0">1</a>
<a href="status.html?p0=mixer&p1=volume&p2=10&player=b8%3A27%3Aeb%3A47%3A49%3Af8&start=0">2</a>
<a href="status.html?p0=mixer&p1=volume&p2=20&player=b8%3A27%3Aeb%3A47%3A49%3Af8&start=0">3</a>
<a href="status.html?p0=mixer&p1=volume&p2=30&player=b8%3A27%3Aeb%3A47%3A49%3Af8&start=0">4</a>
<a href="status.html?p0=mixer&p1=volume&p2=40&player=b8%3A27%3Aeb%3A47%3A49%3Af8&start=0">5</a>
<a href="status.html?p0=mixer&p1=volume&p2=50&player=b8%3A27%3Aeb%3A47%3A49%3Af8&start=0">6</a>
<a href="status.html?p0=mixer&p1=volume&p2=60&player=b8%3A27%3Aeb%3A47%3A49%3Af8&start=0">7</a>
<a href="status.html?p0=mixer&p1=volume&p2=70&player=b8%3A27%3Aeb%3A47%3A49%3Af8&start=0">8</a>
<a href="status.html?p0=mixer&p1=volume&p2=80&player=b8%3A27%3Aeb%3A47%3A49%3Af8&start=0">9</a>
<a href="status.html?p0=mixer&p1=volume&p2=90&player=b8%3A27%3Aeb%3A47%3A49%3Af8&start=0">10</a>
<b>11</b>
<div>
<div id="playList">
<p>Vide<a name="currentsong"></a></p>
</div>
<div id="playlistTab" class="infoTab">
<div id="playlistCommands">
<table id="playlistCommandSpacer"><tr>
<td><span id="btnPlaylistToggleArtwork"></span></td>
<td width="100%">
</td>
<td><span id="btnPlaylistSave"></span></td>
<td><span id="btnPlaylistClear"></span></td>
</tr></table>
</div>
</div>
</div>
</body>
</html>
fred54
Messagepar misterden » 13 Fév 2017 17:22
question bête mais comment je peux faire jouer une piste MP3 ou du moins quelle est la ligne ' HTTP " a utiliser pour cela ? ( j'ai l'ensemble de ma musique installer sur une clé USB branché sur le RSPBERRY PI ou est installé MAX2PLAY )
misterden
Messagepar Nikkos29 » 13 Fév 2017 18:41
Salut
À mon avis c'est le même principe il faut faire une playlist avec ta chanson MP3 et max2play qui pointe sur ta clé USB...
Dans les screenshots précédent tu as l'adresse HTTP à utiliser pour l'appel de la playlist
Nikkos29
