Bonsoir , croyez-vous qu'eedomus se mettra à jour avec le control des lumières via leur nouvelle API.
https://blog.encausse.net/2021/11/14/new-hue-api-v2/
Merci à tous , Cordialement Soundfab.
<?php
Couleurs des icones:
rouge : #FF0000
orange : #FF7400
vert : #01AD1B
bleu : #000FFF
Liste des actions:
1. reset : topology (hueDatas) and debug infos.
2. debug : ON/OFF debug mode
3. debugInfos : dump the traces debugInfos
4. hueDatas : dump the traces debugInfos
5. link_helper : connect to the Philips Hub
6. topology : update the var hueDatas, aka a cache with the identifiers and capacities (light, power, etc..)
7. getState : get the state for a device
8. setSate : set the state for a device
9. topology_helper : display an html page with the attached devices.
$html = '<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
<title>hue and eedomus</title>
<style>
html
background:#222;
color: #fff;
font-family: "proxima-nova","Helvetica Neue",Helvetica,Arial,sans-serif;
header, section {width: 100%; display: block;}
header img, header h1 {display: inline; margin: 25px; vertical-align: middle;}
section {margin-left: 25px;}
form label, form input, form button {margin: 15px 0px; display: block;}
a:link, a:visited { color: #0078e7; }
a:hover { color: red; }
fieldset
border: 0 none;
margin: 0;
padding: 0.35em 0 0.75em;
input[type="text"]
-moz-box-sizing: border-box;
border: 1px solid #ccc;
border-radius: 4px;
box-shadow: 0 1px 3px #ddd inset;
padding: 0.5em 0.6em;
button
font-size: 100%;
padding: 0.5em 1em;
text-decoration: none;
-moz-user-select: none;
cursor: pointer;
line-height: normal;
text-align: center;
vertical-align: baseline;
white-space: nowrap;
border: 0 none rgba(0, 0, 0, 0);
border-radius: 2px;
background-color: #0078e7;
color: #fff;
</style>
</head>
<body>
<header>
<img alt="Hue Personal Wireless Lighting" src="https://secure.eedomus.com/sdk/plugins/hue/hue-logo.png">
<h1>Philips hue and eedomus</h1>
</header>';
$end = '</body></html>';
$hueDatas = loadVariable('hueDatas');
//API
$apiv2_resource = "/clip/v2/resource";
// remplace adresse mac et cle api par *** dans les traces de debug.
function sdk_parse_encrypt($var, $encrypt)
$result = null;
foreach ($var as $key => $val)
$keyencrypt = $key;
$temp = $keyencrypt;
$count = 0;
$temp = str_replace(array_keys($encrypt), $encrypt, $keyencrypt, $count);
if ($count)
$keyencrypt = $temp;
if (is_array($val))
$result[$keyencrypt] = sdk_parse_encrypt($val, $encrypt);
else
$count = 0;
$valencrypt = $val;
$temp = str_replace(array_keys($encrypt), $encrypt, $valencrypt, $count);
if ($count)
$valencrypt = $temp;
$result[$keyencrypt] = $valencrypt;
return $result;
// affiche la variable $var
function sdk_print_debug($var, $bencrypt)
if ($bencrypt || $bencrypt=="false")
$encrypt_keys = loadVariable('encrypt_keys');
if (empty($encrypt_keys))
var_dump($var);
else
var_dump (sdk_parse_encrypt($var, $encrypt_keys));
else
var_dump($var);
// corrige les problemes d'encodage
function sdk_htmlentities($str)
return htmlentities($str, ENT_QUOTES, "UTF-8");
//preg_replace('/\\\\u([\da-fA-F]{4})/', '&#x\1;', $str);
// ajoute un trace de debug
function sdk_append_traces($key, $value, $time=null)
$debug = loadVariable('debug');
if ($debug=='on')
$debugInfos = loadVariable('debugInfos');
if (is_null($time))
$debugInfos[date("d-m-Y H:i:s",time())][$key]=$value;
else if (array_key_exists($key, $debugInfos))
if (is_array($debugInfos[date("d-m-Y H:i:s",$time)][$key]))
$debugInfos[date("d-m-Y H:i:s",$time)][$key][]=$value;
else
$newvalue = array($debugInfos[date("d-m-Y H:i:s",$time)][$key], $value);
$debugInfos[date("d-m-Y H:i:s",$time)][$key]=$newvalue;
else
$debugInfos[date("d-m-Y H:i:s",$time)][$key]=$value;
saveVariable('debugInfos', $debugInfos);
// Ã revoir pour utilisaion ou suppression
function sdk_check_connexion($hue_datas)
$response = httpQuery('https://'.$hue_datas['ip'].$api_hue.$api_resource, 'GET');
if (false == strpos($response, "Error"))
return true;
else
sdk_append_traces('sdk_check_connexion', $response);
return false;
function sdk_HSVtoRGBHue($iH, $S, $V)
$H = $iH/65535*360;
$s = $S/254 ;
$v = $V/254;
$C = $s*$v;
$X = $C*(1-abs(fmod($H/60.0, 2)-1));
$m = $v-$C;
$r = $g = $b = 0;
if($H >= 0 && $H < 60){
$r = $C; $g = $X; $b = 0;
else if($H >= 60 && $H < 120){
$r = $X; $g = $C; $b = 0;
else if($H >= 120 && $H < 180){
$r = 0; $g = $C; $b = $X;
else if($H >= 180 && $H < 240){
$r = 0; $g = $X; $b = $C;
else if($H >= 240 && $H < 300){
$r = $X; $g = 0; $b = $C;
else{
$r = $C; $g = 0; $b = $X;
$R = $r+$m;
$G = $g+$m;
$B = $b+$m;
return array('r'=>round(100*$R), 'g'=>round(100*$G), 'b'=>round(100*$B));
$action = getArg('action');
switch ($action)
case 'reset':
$mac = getArg('mac');
saveVariable('debugInfos', array());
saveVariable('hueDatas', array($mac=>array('key'=>$hueDatas[$mac]['key'])));
echo "<xml><status>ok</status></xml";
break;
case 'debug':
$arg = getArg('status', false);
if ($arg === "off")
saveVariable('debug', 'off');
else if ($arg === "on")
saveVariable('debug', 'on');
$status = loadVariable('debug');
echo '<xml><status>'.$status.'</status></xml>';
break;
case "debugInfos":
$bencrypt = getArg('encrypt', false, true);
sdk_print_debug($debugInfos, $bencrypt);
break;
case 'hueDatas':
sdk_print_debug($hueDatas, $bencrypt);
break;
case 'link_helper':
$mac= getArg('mac');
$hue_bridge_ip = sdk_get_ip_from_ip_or_mac($mac);
$hue_controller_id = $_GET['controller_id'];
$post = '{"devicetype":"eedomus#pluginhue", "generateclientkey":true}';
$response= httpQuery("https://$hue_bridge_ip/api", 'POST', $post);
$json = sdk_json_decode($response);
sdk_append_traces('link_helper_api_json', $json);
if (array_key_exists('error', $json[0]))
if ($json[0]['error']['description']=== "link button not pressed")
// push button
$exec = $_GET['exec'];
$url_to_call = "http://localhost/script/?exec=$exec&action=link_helper&mac=$mac";
if($hue_controller_id !== null)
$url_to_call .= "&controller_id=$hue_controller_id";
echo $html;
echo '<section>';
echo "<form>";
echo "<fieldset>";
echo "<input type=\"hidden\" name=\"url\" value=\"$url_to_call\">";
echo "<input type=\"hidden\" name=\"controller_id\" value=\"$hue_controller_id\">";
echo "<label>Please press the button on the bridge and confirm.</label>";
echo "<button type=\"submit\">Confirm</button>";
echo "</fieldset>";
echo "</form>";
echo '</section>';
echo $end;
else
echo $html;
echo '<div>'.$json[0]['error']['description'].'</div>';
echo $end;
else
//store infos
$hue_application_key = $json[0]['success']['username'];
$hueDatas[$mac]['key'] = $hue_application_key;
saveVariable('hueDatas', $hueDatas);
$encrypt_keys = array($mac => "***", $hue_application_key => "***");
saveVariable('encrypt_keys', $encrypt_keys);
echo $html;
echo "<div>Application linked with the hub. Close this window</div>";
echo $end;
break;
case 'topology':
$key = $hueDatas[$mac]['key'];
// TO REMOVE
$encrypt_keys = array($mac => "***", $key => "***");
if (empty($key))
echo "<xml><status>-1</status></xml>";
die();
$header = array("hue-application-key:".$hueDatas[$mac]['key']);
$response= httpQuery('https://'.$hue_bridge_ip.$apiv2_resource, NULL, NULL, NULL,$header);
$json_device = sdk_json_decode($response);
if (is_null($json_device) || count($json_device['errors']))
$time = time();
sdk_append_traces('topology_helper_devices_header', $header, $time);
sdk_append_traces('topology_helper_devices_json', $json_device, $time);
echo "<xml><status>0</status></xml>";
else
$types = array('grouped_light', 'device', 'zone', 'scene');
foreach ($json_device['data'] as $device)
if (in_array($device['type'], $types))
$hueDatas[$mac]['devices'][$device['id']]['id_v2'] = $device['id'];
$hueDatas[$mac]['devices'][$device['id']]['id_v1'] = $device['id_v1'];
//Zones commit
if (isset($device['metadata']['name'])) {
$hueDatas[$mac]['devices'][$device['id']]['name'] = $device['metadata']['name'];
if (isset($device['children'])) {
$hueDatas[$mac]['devices'][$device['id']]['children'] = $device['children'];
foreach ($device['services'] as $service)
$hueDatas[$mac]['devices'][$device['id']][$service['rtype']] = $service['rid'];
echo "<xml><status>1</status></xml>";
break;
case 'getState':
$id = getArg('id');
$type = getArg('type');
$time = time();
$eeDevice = getArg('eedomus_controller_module_id');
//$hueDatas = loadVariable('hueDatas');
sdk_header('text/xml');
sdk_append_traces('getState',$id,$time);
sdk_append_traces('getState',$type,$time);
if (array_key_exists($id,$hueDatas[$mac]['devices']))
sdk_append_traces('getState_device',$hueDatas[$mac]['devices'][$id],$time);
$battery_state = null;
if (array_key_exists('device_power', $hueDatas[$mac]['devices'][$id]))
$header_V2 = array('hue-application-key:'.$hueDatas[$mac]['key']);
$url_V2 = 'https://'.$hue_bridge_ip.$apiv2_resource.'/device_power/'.$hueDatas[$mac]['devices'][$id]['device_power'];
$response = httpQuery($url_V2, 'GET', NULL, NULL, $header_V2, false, false, $infos);
setBattery($eeDevice, $json['data'][0]['power_state']['battery_level']);
$battery_state = $json['data'][0]['power_state']['battery_state'];
switch ($type)
case 'light':
$url_V1 = 'https://'.$hue_bridge_ip.'/api/'.$hueDatas[$mac]['key'].$hueDatas[$mac]['devices'][$id]['id_v1'];
$url_V2 = 'https://'.$hue_bridge_ip.$apiv2_resource.'/'.$type.'/'.$hueDatas[$mac]['devices'][$id][$type];
$json = httpQuery($url_V2, 'GET', NULL, NULL, $header_V2);
$response = sdk_json_decode($json);
sdk_append_traces('getState', $json, $time);
// ERROR : ["responseV1"]=> string(94) "[{"error":{"type":2,"address":"/lights/14/state","description":"body contains invalid json"}}]"
$status = ($response['data'][0]['on']['on'])?"on":"off";
if ($response['data'][0]['mode']!=="normal")
$status = $response['data'][0]['mode'];
else if($status=="on")
$json = httpQuery($url_V1, 'GET');
$responseV1 = sdk_json_decode($json);
$rgb = sdk_HSVtoRGBHue($responseV1['state']['hue'], $responseV1['state']['sat'], $responseV1['state']['bri']);
$status_rgb=$rgb['r'].','.$rgb['g'].','.$rgb['b'];
$values = getPeriphValueList($eeDevice);
sdk_append_traces("status_rgb", $status_rgb, $time);
sdk_append_traces("values",$values, $time);
if (array_key_exists($status_rgb, $values))
$status = $status_rgb;
echo "<xml><status>$status</status></xml>";
break;
case 'button':
$status = 'disconnected';
if (isset($battery_state))
$status = $battery_state;
break;
case 'temperature':
$temperature = -100;
if ($json['data'][0]['enabled'] && $json['data'][0]['temperature']['temperature_valid'])
$temperature = $json['data'][0]['temperature']['temperature'];
echo '<xml><temperature>'.$temperature.'</temperature></xml>';
break;
case 'grouped_light':
$url_V2 = 'https://'.$hue_bridge_ip.$apiv2_resource.'/'.$type.'/'.$hueDatas[$mac]['devices'][$id]['id_v2'];
$json = httpQuery($url_V2, 'GET', NULL, NULL, $header_V2, false, false, $infos);
sdk_append_traces('getState_url',$url_V2,$time);
sdk_append_traces('getState_response',$response,$time);
break;
case 'scene':
break;
default:
echo "<xml><status>Unknow type</status></xml>";
else
echo "<xml><status>Identifier not found.</status></xml>";
break;
case 'setState':
$actif = getArg('actif', false, true);
if ($actif != true)
echo "unactive";
$id = getArg('id');
$time = time();
$on = getArg('on', false, 'true'); /* V1-V2 : true, false */
$bri = getArg('bri', false, null); /* V1-V2 : brightness */
$hue = getArg('hue', false, null); /* V1 : color */
$sat = getArg('sat', false, null); /* V1 : saturation */
$alert = getArg('alert', false, null); /*V1 : select, lselect */
$effect = getArg('effect', false, null); /* V1 : colorloop */
$effects = getArg('effects', false, null); /* V2 - light : candle, fire */
$scene = getArg('scene', false, null); /* V2 - group : identifier */
$isV1 = $isV2 = false;
if (isset($effects) || isset($scene))
$isV2 = true; /*$effects +($bri)* */
// V2 : values between 0 and 100.
if (isset($bri))
if ($bri<0)
$bri = 0;
else if ($bri>254)
$bri = 254;
$bri = round($bri/254*100);
else
$isV1 = true;
// V1 : values between 0 and 254.
if (isset($bri))
if ($bri<0)
$bri = 0;
else if ($bri>254)
$bri = 254;
if (isset($sat))
if ($sat<0)
$sat = 0;
else if ($sat>254)
$sat = 254;
$isV1str = ($isV1==true)?"true":"false";
$isV2str = ($isV2==true)?"true":"false";
sdk_append_traces("V1", $isV1str, $time);
sdk_append_traces("V2", $isV2str, $time);
$postDatas = NULL;
switch ($type)
case 'light':
if ($isV1)
$postDatas = '{"on":'.$on;
if (isset($bri))
$postDatas .= ', "bri":'.$bri;
if (isset($hue))
$postDatas .= ', "hue":'.$hue;
if (isset($sat))
$postDatas .= ', "sat":'.$sat;
if (isset($alert))
$postDatas .= ', "alert":"'.$alert.'"';
if (isset($effect))
$postDatas .= ', "effect":"'.$effect.'"';
$postDatas .= "}";
$urlV1 = 'https://'.$hue_bridge_ip.'/api/'.$hueDatas[$mac]['key'].$hueDatas[$mac]['devices'][$id]['id_v1'].'/state';
$json = httpQuery($urlV1, "PUT", $postDatas);
sdk_append_traces("datasV1", $postDatas, $time);
sdk_append_traces("urlV1", $urlV1, $time);
sdk_append_traces("responseV1", $json, $time);
echo ($on==="true")?'on':'off';
else if ($isV2)
$postDatas = '{"on":{"on":'.$on.'}}';
$urlV2 = 'https://'.$hue_bridge_ip.$apiv2_resource.'/light/'.$hueDatas[$mac]['devices'][$id]['light'];
$json = httpQuery($urlV2, "PUT", $postDatas,NULL, $header_V2);
sdk_append_traces("postDatas.1", $postDatas, $time);
sdk_append_traces("urlV2.1", $urlV2, $time);
sdk_append_traces("responseV2.1", $json, $time);
$postDatas = '{"effects":{"effect":"'.$effects.'"}';
if (isset($bri))
$postDatas .= ', "dimming":{"brightness":'.$bri.'}';
$postDatas .= "}";
sdk_append_traces("postDatas.2", $postDatas, $time);
sdk_append_traces("urlV2.2", $urlV2, $time);
sdk_append_traces("responseV2.2", $json, $time);
break;
if ($isV1)
if (isset($bri))
if (isset($hue))
if (isset($sat))
if (isset($alert))
if (isset($effect))
if (isset($scene))
$postDatas .= ', "scene":"'.$scene.'"';
$postDatas .= "}";
$urlV1 = 'https://'.$hue_bridge_ip.'/api/'.$hueDatas[$mac]['key'].$hueDatas[$mac]['devices'][$id]['id_v1'].'/action';
else if ($isV2)
//$postDatas = '{"on":{"on":'.$on.'}';
$postDatas = '{"recall":{"action":"active"';
if (isset($bri))
$postDatas .= "}}";
$urlV2 = 'https://'.$hue_bridge_ip.$apiv2_resource.'/scene/'.$scene;
$json = httpQuery($urlV2, "PUT", $postDatas, NULL, $header_V2 );
sdk_append_traces("datasV2", $postDatas, $time);
sdk_append_traces("urlV2", $urlV2, $time);
break;
default:
echo "ERROR : Type not supported";
else
echo "ERROR : Identifier not found";
break;
case 'topology_helper':
if (empty($key))
echo $html;
echo "<div>Application is not linked to the Hub</div>";
echo $end;
die();
$json_resource = sdk_json_decode($response);
$bridge_home = $rooms = $zones = $devices = $lights = $grouped_lights = $scenes = $zoneScenes = $device_powers = $motions = $temperatures = $buttons = array(); //Zones commit
if (is_null($json_resource) || count($json_resource['errors']))
$time = time();
sdk_append_traces('topology_helper_devices_json', $json_resource, $time);
echo $html;
echo "<div>ERROR : json_resource not retrieve</div>";
echo $end;
else
foreach ($json_resource['data'] as $resource)
switch ($resource['type'])
case 'bridge_home':
$keys = array('children', 'services');
foreach ($resource as $key => $values)
if (in_array($key, $keys))
foreach ($values as $value)
$bridge_home[$resource['id']][$key][$value['rtype']][] = $value['rid'];
break;
case 'room':
if (array_key_exists('metadata', $resource))
$rooms[$resource['id']]['name'] = $resource['metadata']['name'];
$rooms[$resource['id']][$key][$value['rtype']][] = $value['rid'];
break;
//Zones commit
case 'zone':
$zones[$resource['id']]['name'] = $resource['metadata']['name'];
if (array_key_exists('product_data', $resource))
$zones[$resource['id']]['product_name'] = $resource['product_data']['product_name'];
$zones[$resource['id']][$key][$value['rtype']][] = $value['rid'];
break;
case 'device':
$devices[$resource['id']]['name'] = $resource['metadata']['name'];
$devices[$resource['id']]['product_name'] = $resource['product_data']['product_name'];
$devices[$resource['id']][$key][$value['rtype']][] = $value['rid'];
break;
case 'light':
//Zones commit
if (array_key_exists('owner', $resource))
$lights[$resource['id']] = $resource['owner']['rid'];
break;
$grouped_lights[$resource['id']]['owner'][$resource['owner']['rtype']] = $resource['owner']['rid'];
break;
case 'scene':
$scenes[$resource['id']]['name'] = $resource['metadata']['name'];
if (array_key_exists('group', $resource))
$scenes[$resource['id']][$resource['group']['rtype']] = $resource['group']['rid'];
break;
case 'device_power':
break;
case 'motion':
break;
case 'temperature':
break;
case 'button':
break;
//Zones commit
foreach ($scenes as $sceneId => $scene)
if (isset($scene['zone']))
$zoneId = $scene['zone'];
$zoneScenes[$zoneId][$sceneId] = $scene['name'];
$time = time();
sdk_append_traces('topology_helper_bridge_home', $bridge_home, $time);
sdk_append_traces('topology_helper_rooms', $rooms, $time);
sdk_append_traces('topology_helper_zones', $zones, $time); //Zones commit
sdk_append_traces('topology_helper_devices', $devices, $time);
sdk_append_traces('topology_helper_grouped_lights', $grouped_lights, $time);
sdk_append_traces('topology_helper_scenes', $scenes, $time);
echo $html;
$tags = array('grouped_light'=>'Groupe');
foreach ($bridge_home as $bridge)
echo '<ul>';
echo '<li><h1>Bridge :</h1></li>';
echo '<ul>';
// Devices
$count = sizeof($bridge['children']['device']);
if ($count > 0)
echo '<li><h2>Devices :</h2></li> <ul>';
foreach ($bridge['children']['device'] as $device )
echo '<li>'.sdk_htmlentities($devices[$device]['name']).' ('.$devices[$device]['product_name'].') => <b>'.$device.'</b></li>';
if ($count > 0)
echo '</ul>';
// Services
$count = sizeof($bridge['services']);
if ($count > 0)
echo '<li><h2>Services :</h2></li>';
foreach ($bridge['services'] as $key => $service)
$count2 = sizeof($service);
if ($count2 >0)
echo '<ul>';
foreach ($service as $value)
if (array_key_exists($key, $tags))
echo '<li>'.$tags[$key].' => <b>'.$value.'</b></li>';
else
echo '<li>'.$key.' => <b>'.$value.'</b></li>';
if ($count2 >0)
echo '</ul>';
// Zones commit
if (!empty($zones))
echo '<li><h2>Zones :</h2></li><ul>';
foreach ($zones as $zoneId => $zone)
echo '<li><h3>'.sdk_htmlentities($zone['name']).'</h3>';
echo '<ul>';
if (isset($zone['children']['light']))
foreach ($zone['children']['light'] as $lightId)
$deviceId = isset($lights[$lightId]) ? $lights[$lightId] : null;
if ($deviceId && isset($devices[$deviceId]))
echo '<li>'. sdk_htmlentities($devices[$deviceId]['name']). ' ('.sdk_htmlentities($devices[$deviceId]['product_name']).') => <b>'.$lightId.'</b></li>';
else
echo '<li>Light => <b>'.$lightId.'</b></li>';
if (isset($zone['services']['grouped_light'][0]))
echo '<li>Grouped light => <b>'.$zone['services']['grouped_light'][0].'</b></li>';
if (isset($zoneScenes[$zoneId]))
echo '<ul><li><h4>Scènes</h4></li><ul>';
foreach ($zoneScenes[$zoneId] as $sceneId => $sceneName)
echo '<li>'.sdk_htmlentities($sceneName).' => <b>'.$sceneId.'</b></li>';
echo '</ul></ul>';
echo '</ul></li>';
echo '</ul>';
$count = sizeof($bridge['children']['room']);
if ($count >0)
echo '<li><h2>'.sdk_htmlentities('Pièces :').'</h2></li> <ul>';
foreach ($bridge['children']['room'] as $room )
echo '<li><h3>'.sdk_htmlentities($rooms[$room]['name']).'</h3></li>';
$count2 = sizeof($rooms[$room]['children']['device']);
if ($count2 >0)
echo '<ul><li><h4>Produits</h4></li>';
echo '<ul>';
foreach ($rooms[$room]['children']['device'] as $device)
if ($count2 >0)
echo '</ul>';
echo '</ul>';
$count2 = sizeof($rooms[$room]['services']);
if ($count2 >0)
echo '<ul><li><h4>Groupes</h4></li>';
echo '<ul>';
foreach ($rooms[$room]['services'] as $key => $service)
else
if ($count2 >0)
echo '</ul>';
echo '</ul>';
/*$count2 = sizeof($scenes);
if ($count2 >0)
echo '<ul><li><h4>'.sdk_htmlentities('Scènes:').'</h4></li>';
echo '<ul>';
$hasScene = false;
foreach ($scenes as $key_scene => $scene)
if ($scene['room'] == $room)
if ($hasScene==false)
$hasScene = true;
echo '<ul><li><h4>'.sdk_htmlentities('Scènes:').'</h4></li><ul>';
echo '<li>'.sdk_htmlentities($scene['name']).' => <b>'.$key_scene.'</b></li>';
if ($hasScene)
echo '</ul></ul>';
if ($count > 0)
echo '</ul>';
echo '</ul>';
echo '</ul>';
echo $end;
break;
default:
echo 'Action unknown';
?>Retour vers Scripts & Périphériques du store
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 44 invité(s)
