[Store] Volets et stores Somfy (Bridge Connexoon)
Re: [Store] Volets et stores Somfy (Bridge Connexoon)
Messagepar Herric » 23 Déc 2021 23:54
Hi @Horia,
Sorry again but you misunderstand how the script and the somfy API work. I wrote the V2 and V3 scripts so let me explain ...
Since I updated the polling time to 60 min I did not see any blacklisting
I already answered that.
Take 5 min to read the excellent @dommarion post concerning the reasons choosing centralized polling instead of devices polling.
not sure you are right with your theory that the 2 min login and unlimited API calls
This is not a theory, this as been tested and validated, using network analysis tools, and raw responses to API requests. API fetch requests can run every second, leading to thousands of requests per hour without any problem.
Last, in my view, any public API, has to be authenticated on each request
It's not a public API, it's the specific webapp and smartphone app API.
It accepts 1 login request and n fetch requests using a subscription token.
If you wait more than 2 min without any fetch request, you just loose the token and need to re-login.
With v2 I never had ANY issue, with v3 until I reduced the polling time as I said, multiple times
V3 came with a lot of improvements concerning events handling, cpu tuning, devices templates, and balcklist protection. But V2 and V3 use the same API engine : login request -> event subscribe request -> event fetch requests.
So if you experienced a blaklisting, this is because you fell in a specific case that could not be anticipated.
MasterData status changes are not issues (except blaklist of course), they just reflect events coming from the cloud. Please, read a translation of this post to better understand how MasterData status are rendered.
trying to pull agresivly the intermediate states will trigger the blacklisting imho
The script do not try to pull intermediat states, it just fetches for events from the cloud. If there's no event, there's no intermediate state. If there are lots of events, there are lots of intermediate states.
eedomus polling is based on minutes :
- less than 1 is not possible
- 1 is ok
- 2 and higher makes you loose the token
Knowing that, feel free to set the MasterData polling to 24 if this is ok with your environment. But this is not our recommandation.
Herric
Herric
Messagepar Pela » 26 Déc 2021 11:34
Bonjour a tous, et également joyeux Noël !
Je viens ici pour poser une question pour laquelle je ne trouve pas de réponses malgré de longues recherchez.
Je bien cru comprendre qu'il est possible de faire communiquer une box eedomus avec une box tahoma Switch ou la passerelle connexoon, pour intégrer des volets roulants avec protocole io homecontrol, le tout grâce à un plugin développé par des gens très compétents qui se trouve ici...ou pas loin^^.
Aujourd'hui la passerelle connexoon ne semble plus dispo(et limitée en nombres d'équipements connectables) et la tahoma Switch me semble très chère et pas très évolutive.
Par contre j'ai repéré le kit de connexion Somfy ( ou tahoma mini pour certain) qui semble tout à fait me correspondre car pas trop chère. Il permettait de piloter mes 9 volets et mon portail pour le moment
https://boutique.somfy.fr/kit-de-connectivite.html
Est ce que ce dernier va être compatible de la même façon avec eedomus et le plugin ??
Merci d'avance pour votre aide a éclaircir ce point.
Bonne fête à tous.
Pela
Messagepar Herric » 26 Déc 2021 12:56
Pela a écrit:Bonjour a tous, et également joyeux Noël !
Bonne fête à tous.
Bonjour @Pela,
Très bonne question, et réponse pas evidente du tout.
Le plug-in est compatible avec l'application Tahoma classique et Tahoma Switch via l'api du cloud somfy.
Dans le lien que tu as envoyé Il est indiqué qu'il n'y a pas d'accès au cloud ni à l'api ... et dans la notice d'utilisation il est mentionné l'application tahoma. Donc des informations contradictoires qui ne permettent pas de trancher.
La limite pour 69 EUR je te conseillerais de trouver un revendeur qui accepte de reprendre ton kit s'il ne correspond pas au besoin. Cela te permettrait de tester la connectivité avec eedomus. Mais tu risques de jouer les cobayes et nous sommes pas forcément toujours connectés au forum pour t'aider dans le délai qui te sera imposé ...
Désolé de ne pouvoir t'aider plus mais si personne n'a déjà testé ce kit, on ne peut être sûr de rien, surtout avec somfy.
Bon courage et tient au nous au courant, Il y a plusieurs personnes qui connaissent bien le plug-in sur ce forum.
Herric
Envoyé de mon SM-G991B en utilisant Tapatalk
Herric
Messagepar Pela » 26 Déc 2021 14:56
Bonjour Herric,
Merci beaucoup pour ton retour très clair.
Pour être précis, je n'ai pas encore d'eedomus. Je suis en phase de prise d'infos avant de me lancer dans une domotisation progressive de la maison.
J'avoue être complètement novice dans le domaine mais ça fait une semaine que je m'y interesse, en lisant tout ce que je trouve sur le sujet....pas facile tout ça :)
Je vais prendre mon temps avant d'investir mes euros, étudier la meilleure solution par rapport à mes besoins et mes équipements déjà présent chez moi.
Du coup pour la compatibilité avec ce kit Somfy, peut être quelqu'un aura testé et saura me dire en patientant un peu.
Encore merci pour ta réponse.
Pela
Messagepar Dom-54 » 26 Déc 2021 17:34
Bonsoir Pela,
J’avais également jeté un coup d’oeil avec le lien indiqué mais pas plus à apporter que la réponse d’Herric … désolé!
Bon courage.
Dom-54
Messagepar dommarion » 26 Déc 2021 17:35
Bonne fête à tous.
Bonjour Pela,
J'ai lu a réponse de Herric, et j'ai regardé sur le site de Somfy. Je crois comprendre en effet que cet équipement est une Tahoma Mini, dans le sens où elle est limitée en nombre d'appareils connectables (maxi 20 au lieu de >200), 20 scénarios manuels (au lieu de 40) et pas de scénarios planifiés, ni avancés. Etc... Plusieurs restrictions en terme de capacités et performances. :(
Cela permet de faire fonctionner tous tes appareils SOMFY avec l'application smartphone Tahoma, donc tu as accès à la même API et du coup je suis presque sûr que le Plugin SOMFY V3.0 va fonctionner avec cet équipement. :roll:
Il est effectivement moins cher que la Swift puisque 69€ au lieu de 199€. Pour une passerelle c'est tout a fait suffisant en effet.
Néanmoins j'attire ton attention sur la non-compatibilité avec:
- Sécurité et alarme (beaucoup de développements ont été fait dans la V3.0)
- Thermostats (idem)
- Capteurs (idem)
- Philips Hue (idem)
Enfin pas de backup en cas de coupure internet.
Pour compléter la réponse de Herric, je pense que Cloud et Local API sont des partenaires/protocoles au même titre que io-homecontrol, Philips HUE et Zigbee 3.0, et ne compromettent pas la compatibilité avec le Plugin SOMFY V3.0 eedomus. :)
Ma recommandation serait de passer à la Tahoma Switch qui est plus chère en effet mais qui te laisse le champs libre pour faire évoluer ta domotique y compris avec du Zigbee 3.0 (qui est manquant à la eedomus sans clef complémentaire). :P
Bonne soirée.
dommarion
dommarion
Messagepar Pela » 26 Déc 2021 18:27
Merci Dom-54.
Bonsoir Dommarion, Merci beaucoup pour ton avis.
Effectivement cette "mini tahoma" annonce des fonctionnalités bien limitées par rapport à sa grande soeur.
Cependant elle va me permette de prendre la main a distance sur mes 9 volets Somfy Io dans un premier temps, et si comme tu le penses elle peut servir de passerelle "protocole io" a un système domotique plus poussée....c'est le top pour moi.....enfin je crois ;)
Je débute vraiment, mais j'ai ce désire d'essayer de faire quelques choses de mes équipements pas vraiment fait pour vivre ensemble je crois...volets Io, alarme diagral, chauffe eau thermodynamique et radiateur Atlantic sur un système delta dore Calybox 1020wt dont je ne sais pas me servir...et un poêle à pellets edilkamin non connecté...une station Oregon...et bien sûr intégrer ensuite pleins d'évolution et petits capteurs.
Bref un gros gros bordel pour moi et mon faible niveau de connaissances, mais j'ai la foi, je vais me mettre à niveau.
Est ce qu'une box eedomus au milieu de tout ça a du sens ?...je ne serais même pas le dire. :lol:
Bref pour en rester au sujet de ce topic, merci pour vos avis, je reste intéressé par toute expérience qui confirmerai ou pas l'association plugin somfy v3 eedomus et tahoma mini.
Pela
Messagepar dommarion » 27 Déc 2021 16:50
Bonjour Pela,
Je comprends que tu souhaites utiliser tes équipements avec une box domotique. Il faut en premier lieu réflechir aux compatibilités, j'ai fait quelques recherches sur le forum et comme tu pourras le voir, ce n'est pas gagné !
Quand tu fais un choix de Box domotique, il faut aussi savoir quels équipements/capteurs tu veux piloter et récupérer, vérifier que les protocoles sont compatibles, et si non compatible (non-propriétaires si possible), si il existe des interfaces type RFXCOM ou RFPlayer ou ...
Il est souvent moins cher et plus fiable de bâtir toi même ta solution avec une architecture et des protocoles ouverts.
Pela a écrit:alarme diagral
Voir un post du forum:
viewtopic.php?f=14&t=7363
Pela a écrit:chauffe eau thermodynamique et radiateur Atlantic sur un système delta dore Calybox 1020wt dont je ne sais pas me servir...
Voir les posts du forum:
viewtopic.php?f=17&t=2733
viewtopic.php?f=14&t=8790
Pela a écrit:une station Oregon
viewtopic.php?f=17&t=9350
Bon courage
dommarion
dommarion
Messagepar LouLouFactory » 28 Déc 2021 10:45
Bonjour à tous et bonnes fêtes,
Cela fait maintenant 10 jours que mon puglin indique Somfy Cloud Off - j'ai patienté en me disant que ca allait revenir tout seul mais rien n'y fait...
J'ai lu les pages précédentes, je comprends qu'il y a une correction sur une version 3.1 qui est sortie mais j'ai l'impression que sur le store, il n'y a que la version 3.0.
Est ce que qq aurait la gentillesse de m'expliquer ce que j'ai visiblement raté comme épisode :-)
Merci!
LouLouFactory
Messagepar Dom-54 » 28 Déc 2021 11:51
Bonjour Louloufactory,
La version 3.1 est encore en cours de tests donc normal que tu ne la vois pas encore apparaître, ça ne devrait pas tarder ;)
Sinon pour te débloquer débranches ta box Eedomus pendant 1 h (choisis la période qui te gêne le moins!) après re-connexion ton master data devrait repasser au vert sous 1 a 2 mn sous réserve que ta box Somfy et ta connexion soit ok!
Bonne journée.
Dom-54
Messagepar LouLouFactory » 28 Déc 2021 16:59
Dom-54 a écrit:Bonjour Louloufactory,
Bonne journée.
Top. Merci! et merci pour tout le travail que vous faites pour tout le monde!
LouLouFactory
Messagepar Herric » 28 Déc 2021 23:28
Bonjour @LouLouFactory,
10 jours ... ça correspond à plusieurs messages relatant le même problème ... et a plusieurs mises à jour côté somfy. Certains ont été blacklistés, d'autres non.
Une fois blacklisté, comme le script continue à faire des requêtes en permanence, tu ne peux t'en sortir qu'en "coupant" la liaison comme te l'a indiqué @Dom54.
Nos derniers tests avec @dommarion montrent que la v3.1.0 serait plus robuste par rapport à ce problème. J'attends la rentrée avant de la publier.
Herric
Messagepar Horia » 30 Déc 2021 15:21
@Herric,
I appreciate the update, I understand the authentication followed by a token in the API queries and the 2 min timeout per token.
I only have two devices that are rarely controlled during a day, a velux (with a rule to open by humidity, and a timeout of 10 min, the velux doesn't open if rain (opens 90% only), so the rule retries in 10 min) and a store on the velux that opens if good weather in a nutshell (temp, rain, wind), hence from what else can create the the blackslist in the Somfy Cloud if not the other two liste.php devices?
I disabled the device counter (polling on 0) and I did move the Master Data to 12 hours polling...Let's see.
I'll update after I see more history data, I understand disables the token logic in v3.
Horia
Maison avec eedomus+, 200 dispositifs(60 en zwave/+, 10 en RFXcom, 5 cameras, les restes virtuel), automatisation éclairage, sécurité maison, environnement, access, chauffage, notifications, agenda.
Horia
Messagepar jluc2808 » 07 Jan 2022 12:05
Bonne fête à tous.
bonjour, tardivement mais réponse,
j'ai posé directement la question sur le forum Pro somfy, afin de savoir si le kit de connectivité en question permettait d'accéder à l'API somfy Tahoma, la réponse est claire de la part d'un yellow SOMFY (donc personnel SOMFY habilité à répondre pour le compte de la société)
"A date les API ne sont pas compatible avec le kit de connectivité."
donc la solution est soit connexoon, tahomaV2 (les 2 ne sont plus commercialisées) ou tahoma switch (la seule disponible en commercialisation)
Il y a bien la solution KLF200 en local mais je ne sais pas si la solution eedomus proposée permet de dialoguer avec.
jluc2808
Messagepar RAR69 » 12 Jan 2022 15:18
Le Bridge Cozytouch Atlantic Thermor, toujours en vente est le même que celui de Somfy...
Protocole IO...
La solution fonctionnait avec des volets Somfy. Je me renseigne pour savoir si le bridge fonctionne toujours chez mon cousin...
EDIT: après consultation son bridge Cozytouch (Connexoon chez Somfy) est toujours fonctionnel
Roland
PS : bons vœux à toutes et tous
RAR69
Messagepar dommarion » 13 Jan 2022 13:30
Petit soucis avec le Plugin SOMFY... :roll:
Ce jour à 10:34:29 passage du MasterData en Cloud OFF, puis à 10:35:30 Login verrouillé, puis enfin à 10:36:29 Cloud ON/Box ON.
Les devices sont toutes restées en "connexion" depuis 10:34:29, comme si le MasterData était figé et ne distribuait plus les états des devices.
Investigation en cours...
Si vous avez rencontré le même problème merci de nous le mentionner, pour améliorer le retour d'information et trouver la solution. :geek: :ugeek:
bonne journée, :D
dommarion
dommarion
Messagepar Dom-54 » 13 Jan 2022 16:44
de mon coté aussi ce matin à 10h35 le master data est passé en Cloud ON / Box OFF alors que comme d'habitude rien vu côté Box et liaison Somfy OK (sur l'iphone). Puis j'ai rebooté ma box SOMFY, ça n'a rien changé! Puis j'ai vérifié l'accès login/pw Somfy => OK, ensuite j'ai rebooté la box Eedomus pendant 5 mn, RIEN c'est resté bloqué !?
Constat:
Les actionneurs semblaient fonctionner via Eedomus (Volets, lampes , ...)
Les détecteurs et capteurs ne fonctionnaient plus via Eedomus (Ouvertures, présence, température, ...), par contre ils fonctionnent bien dans l'appli SOMFY.
Le pb a pu être réglé via la ligne de cde de reset.
Bonne soirée.
Dom-54
Messagepar dommarion » 14 Jan 2022 09:01
Ce matin "rebelotte", même problème à 8h00.
Résolu de la même manière "Reset verrouillage/pause" et tout est reparti après 2 min.
Bonne journée
dommarion
dommarion
Messagepar Dom-54 » 14 Jan 2022 09:30
Bonjour Dommarion et à tous,
Effectivement ce matin à 08h00 pile MasterData Cloud OFF et à 08h02 le MasterData est repassé en Cloud ON/Box ON ... Mais plus d'accès à la box Somfy ni au Thermostat connecté non plus pendant une bonne demi-heure !
Après vérification sur le forum Somfy il y avait effectivement ce bandeau:
Chers utilisateurs,
Nous rencontrons actuellement des ralentissements sur nos serveurs SOMFY TAHOMA et CONNEXOON, entraînant des difficultés à piloter et vous connecter à votre système depuis l’application.
Nos équipes sont actuellement dédiées à la résolution du souci et nous vous tiendrons informés de l’avancement de la situation via ce bandeau d’information.
Veuillez nous excuser pour la gêne occasionnée et nous vous remercions pour votre compréhension.
L’équipe des Yellow’s SOMFY
Par contre mon MasterData est bien Cloud ON/Box ON mais il a mis pas mal de temps à se débloquer une bonne heure !!
Bonne journée à tous.
Dom-54
Messagepar dommarion » 14 Jan 2022 15:04
Merci Dom-54, de nouveau cet après-midi à 14h37 de nouveau Cloud OFF, mais là 2 min après tout est reparti tout seul. Je pensais bien que SOMFY faisait quelque chose car je n'avais jamais eu de Cloud OFF précédemment.
Cette opération nous aura permis d'identifier d'autre cas et donc d'améliorer la version. V3.1 va bientôt sortir...
Bonne journée
dommarion
dommarion
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 43 invité(s)
