jluc2808 a écrit:faut relancer un register avec tous les paramètres supplémentaires, mais attention ça ajoute une instance de notification au NUKI qu'il faut enlever .
_____________________________________________________________________________________________
[15:18:08.362] [2022-02-01] Starting script [http_exec.php] pid->3576
[15:18:08.362] ## DEBUG: Allowing db update
[15:18:08.365] ## DEBUG: Allowing db connexion to maintain
[15:18:08.366] ## INFO: Launched from [daemon_rule] [controller_module_id=2622697]
[15:18:08.455] ## INFO: Debug mode is OFF.
[15:18:08.459] HTTP [GET] Query -> [http://192.168.0.xx:8080/lockAction?nukiId=xx&action=2&token=xx]
[15:18:08.507] [2022-02-01] Starting script [http_exec.php] pid->3576
[15:18:08.508] ## DEBUG: Allowing db update
[15:18:08.508] ## DEBUG: Allowing db connexion to maintain
[15:18:08.509] ## INFO: Launched from [daemon_rule] [controller_module_id=2622683]
[15:18:08.513] ## INFO: Debug mode is OFF.
[15:18:08.520] HTTP [GET] Query -> [http://192.168.0.xx:8080/lockAction?nukiId=xx&action=2&token=xx]
[15:18:09.386] Result -> [HTTP:200] in 1s
[15:18:09.387] Creating request from 'putReq' [/mnt/flash/puch/outbox/2022.02.01_15.18.09_387302_cm2622697.req]
[15:18:09.389] ## DEBUG: Disabling db update
[15:18:09.401] CPU Usage : User 40 ms (cumulated 310), System 0 ms (cumulated 60), [/etc/eedomus/cpu_http_exec.txt] written
[15:18:09.402] Done
[15:18:09.403] Quitting child thread [28838] after 945ms (parent was [daemon_rule])
[15:18:12.730] Result -> [HTTP:200] in 5s
[15:18:12.731] Creating request from 'putReq' [/mnt/flash/puch/outbox/2022.02.01_15.18.12_731091_cm2622683.req]
[15:18:12.733] ## DEBUG: Disabling db update
[15:18:12.796] CPU Usage : User 40 ms (cumulated 350), System 0 ms (cumulated 60), [/etc/eedomus/cpu_http_exec.txt] written
[15:18:12.797] Done
[15:18:12.799] Quitting child thread [28839] after 4280ms (parent was [daemon_rule])
jluc2808 a écrit:si tu as déjà intégré le script depuis le store, alors tu peux faire ce qui suit:
- changer le script depuis celui qui est dans la 1.5 en l'important sans tes scripts (et tu vas écraser celui qui existe), si il a le même nom cela va automatiquement remplacer celui de la 1.3
*** pour t'en assurer, tu fais un édit du script et tu dois voir la version en début de programme ****
- ajouter les équipements manquants (cad, la porte)
- ajouter dans les équipements existants la partie % pour la batterie.
pour les termes :
register est obligatoire: cela permet d'enregistrer (register) dans les variables de eedomus les id des équipements associés au NUKI et de dire à NUKI (l'api), de te renvoyer (callback) le status de la porte / serrure à chaque fois que ceux-ci sont modifiés (que ce soit par eedomus par l'appli nuki ou manuellement)
*** c'est pour cela que cette action est obligatoire *****
Utilisateurs parcourant ce forum : Aucun utilisateur inscrit et 223 invité(s)
