KIRA problem with 2-digit channels
HTTP sensors and actuators
Messagepar ivanruban » 21 Juil 2014 11:51
Hi all. I use Keene KIRA to control TV by IR. It works fine when I select a single channel. But when it relates to 2-digit channels I use macro and have a problem here. The example is for "58 Discovery channel" which has two digits "5" and "8".
I tried to use macro with 1 second delay between commands "5" and "8" - and in half of cases I get channel 5 or channel 8 instead of channel 58! :( Then I also tried the macro with 0 seconds delay - the same story.
But on the portal if I press fast "5" and then in 0.5 second I press "8" - then it works more stable. But with the interface of eedomus it is difficult to do that - the list of values hides when user press a button on a device. I also cannot set a macro with 0.5 second delay, the minimum is "1 sec" in eedomus
In Fibaro HC2 for comparison - you can have a set of buttons on the mobile's screen and then pressing of several buttons in a row is much easier. I never tested HC2 with KIRA but with WF2IR it works just perfect. :!:
The problem with 2-digit channels is actually related to how the command is executed in eedomus. I can see on KIRA - it sends first IR-code, then several 2-4 seconds delay :!:, then second IR-code.
    1. Is it a problem in eedomus or KIRA perfomance?
    2. Is there anyone who has similar problems?
    3. Any solutions for that? May be php-script with 0.5 second delay?
    4. Does WF2IR work better than KIRA?
ivanruban
Re: KIRA problem with 2-digit channels
Messagepar ivanruban » 21 Juil 2014 13:03
I have found the solution - php script. I don't know why eedomus makes such big delays between calls (2-4 seconds) - but I guess it is a perfomance issue in eedomus.
Anyway http-queries work MUCH faster in php script, so below is example for channel "12". Works 100%. It is just a test-script. The script should be parametrised and then called from eedomus virtual device with "channel number" parameter.
<?php
// URL to KIRA, adjust according to your buttons
$url = "http://192.168.YOUR.IP/remote2.htm?button";
$ch1 = "002";
$ch2 = "003";
$ch3 = "004";
$ch4 = "005";
$ch5 = "006";
$ch6 = "007";
$ch7 = "008";
$ch8 = "009";
$ch9 = "010";
$ch0 = "011";
// query
httpQuery($url . $ch1);
httpQuery($url . $ch2);
ivanruban
Messagepar Peedjy » 23 Juil 2014 08:31
Hi ivanruban
Can you please post a full script exemple, with more than one button?
For exemple to mange channel 10 to 20 etc...
Did you also manage the simple touch (from 0 to 9) with your script or directly from the eedomus?
Thanks
Peedjy
Peedjy
Messagepar galaksy2001 » 23 Juil 2014 20:10
Messagepar ivanruban » 24 Juil 2014 08:25
Peedjy a écrit:Can you please post a full script exemple, with more than one button?
As I told that code is just an example to show how it is possible to fix this problem in a script. That script should be parametrized in order to make it universal of course.
Anyway here is the modified version of the script:
<?php
// URL to KIRA
$url = "http://" . getArg('kira_url');
// Channel f.ex. 125 or 48
$channel = getArg('channel');
// Channels definition [Number] => [ID in KIRA]
$kira_channels = array (
    "1" => "002",
    "2" => "003",
    "3" => "004",
   "4" => "005",
   "5" => "006",
   "6" => "007",
   "7" => "008",
   "8" => "009",
   "9" => "010",
   "0" => "011"
// Now send HTTP request for channels
$num_requests = strlen($channel);
for ($i = 0; $i < $num_requests; $i++) {
   $ch = $channel[ $i ];
   $kira_ch = $kira_channels[ $ch ];
   echo "Executing request for channel '". $ch ."' on KIRA (". $kira_ch .")<br>\r\n";
   httpQuery($url . $kira_ch); // that does the magic...
To use it in eedomus:
0) I assume you saved your IR codes in memory of KIRA128 and know the saved button IDs in KIRA.
1) Save the script as kira_channel.php, edit values of the kira_channels array in the script according to your saved button IDs in KIRA128
2) Upload kira_channel.php to your eedomus box (in http://192.YOUR.EEDOMUS.IP/script/)
3) Create HTTP actuator, set user variables:
    VAR1 = kira_channel.php
    VAR2 = 192.YOUR.KIRA.IP/remote2.htm?button
4) Create value for each channel you need, for example
Now you can execute channel Discovery which will execute '6'+'7' on KIRA
For other channels: URL is always the same. Description and Parameters (&channel=NUMBER) are different for every channel.
Enjoy! :D
ivanruban
Messagepar ivanruban » 14 Déc 2014 19:22
Denisstar a écrit:Зимний праздник на подходе,
Старый год от нас уходит,
В дверь стучится Новый год.
Пусть с метелью и порошею
Принесет он все хорошее:
Детям - радость, как и прежде,
Взрослым - счастье и надежды.
Пусть новогодний Дед Мороз
Подарит счастья целый воз,
Здоровья крепкого в придачу,
Во всем задуманном удачу,
Мира, дружбы, шуток, ласки,
Чтобы жизнь была, как в сказке!
Всех форумчан, с Наступающими!!!))
Вот уж порадовали и удивили! Думал только французы едомусом пользуются.
Взаимно и с наступающим! :D
ivanruban
Messagepar pavimanike » 05 Oct 2023 08:18
To address the delay issue with 2-digit channels, you could explore writing a custom script, possibly in PHP, that sends the IR commands with a 0.5-second delay between them. This script could be triggered by your eedomus controller. However, keep in mind that implementing custom scripts may require some technical expertise.
pavimanike
Retour vers HTTP requests
