| Fibaro Motion Sensor (FGMS-001) Battery FYI for comments http://forum.eedomus.fr/viewtopic.php?f=38&t=11625 |
| Auteur: | Horia [ 12 Nov 2022 11:32 ] |
| Sujet du message: | Fibaro Motion Sensor (FGMS-001) Battery FYI for comments |
Hi All, I have many Fibaro sensors installed. Since 20219, I timed based (5min interval) or disabled when not required their temperature and light updates, and saw battery improvements. For some of them, where there is constant movement, a battery from January 2020, arrived to be 3% in August 2022 and I decided to keep it see what happens. Even now, it shows 3%, almost 3 months past. In other cases where there is less movement last battery change was almost 4 years away... The only disturbance is to see in the web and app UIs the notifications for the low battery levels...They start from below 10%, and is annoying to close them. In my view, eedomus should enable customisable notification levels, and as last resort we have the notification for when the sensor has not communicated over a configured time. All this as FYI and open for comments, Thanks, and best regards, Horia |
| Auteur: | lyly19 [ 29 Juin 2024 02:59 ] |
| Sujet du message: | Re: Fibaro Motion Sensor (FGMS-001) Battery FYI for comments |
You should contact Eedomus support to suggest a custom low-battery notification feature. In the meantime, you can check and turn off notifications in the app's settings or web interface if this option is available. This will help reduce annoyance from low battery notifications and focus on monitoring more important devices. |
| Auteur: | CharlotteMurphy [ 22 Nov 2024 08:49 ] |
tu as raison |
