Philips HUE - script not found
Let's talk about the box itself
Messagepar fernandez_jg » 10 Mars 2018 20:09
Hi,
I am a new eedomus user and I am trying to integrate the Philips HUE bridge (version 2) with eedomus.
I have set a fixed IP on my HUE bridge and I follow the instruction defined in the documentation
http://doc.eedomus.com/en/index.php/Eedomus_and_Hue
But when I try to get the username I get the following error message:
Script not found [hue_include.php]
I have try to review the available scrips following the address,as described in https://doc.eedomus.com/es/index.php/Scripts, but no script it is reported to be available
http://ip_de_su_controlador_eedomus/script/
Please can you help me to solve the issue.
Best regards
fernandez_jg
Re: Philips HUE - script not found
Messagepar merguez07 » 10 Mars 2018 20:33
Hi,
weird, I dont have a Hue but I installed the script and I had no problem
try to manually put the script hue_include.php
* This php script is part of the eedomus scripting tools.
* It helps create a new user for the hue bridge.
* This user will be used later to control the hue lights.
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
<title>hue and eedomus</title>
<style>
   html
      background:#222;
      color: #fff;
      font-family: "proxima-nova","Helvetica Neue",Helvetica,Arial,sans-serif;
   header, section {width: 100%; display: block;}
   header img, header h1 {display: inline; margin: 25px; vertical-align: middle;}
   section {margin-left: 25px;}
   form label, form input, form button {margin: 15px 0px; display: block;}
   a:link, a:visited { color: #0078e7; }
   a:hover { color: red; }
   fieldset
      border: 0 none;
      margin: 0;
      padding: 0.35em 0 0.75em;
   input[type="text"]
      -moz-box-sizing: border-box;
      border: 1px solid #ccc;
      border-radius: 4px;
      box-shadow: 0 1px 3px #ddd inset;
      padding: 0.5em 0.6em;
   button
      font-size: 100%;
      padding: 0.5em 1em;
      text-decoration: none;
      -moz-user-select: none;
      cursor: pointer;
      line-height: normal;
      text-align: center;
      vertical-align: baseline;
      white-space: nowrap;
      border: 0 none rgba(0, 0, 0, 0);
      border-radius: 2px;
      background-color: #0078e7;
      color: #fff;
</style>
</head>
<body>
<header>
   <img alt="Hue Personal Wireless Lighting" src="https://secure.eedomus.com/sdk/plugins/hue/hue-logo.png">
   <h1>Philips hue and eedomus</h1>
</header>
<section>
<?php
$exec = $_GET['exec'];
$hue_bridge_ip = $_GET['hue-bridge-ip'];
$hue_username = getArg('user_name');
$hue_controller_id = $_GET['controller_id'];
$step = $_GET['step'];
if($exec === null || $exec === "") {
   echo "<p>The script cannont execute correctly</p>";
else {
   if($hue_bridge_ip === null || $hue_bridge_ip === "") {
      // Ask for hue bridge ip address
      echo "<form>";
      echo "<fieldset>";
      echo "<input type=\"hidden\"  name=\"exec\"  value=\"$exec\">";
      echo "<input type=\"hidden\"  name=\"step\"  value=\"1\">";
      //echo "<input type=\"hidden\"  name=\"user_name\"  value=\"$hue_username\">";
      if($hue_controller_id !== null)
         echo "<input type=\"hidden\"  name=\"controller_id\"  value=\"$hue_controller_id\">";
      echo "<label for=\"hue-bridge-ip\">Please enter your hue ip address:</label>";
      echo "<input id=\"hue-bridge-ip\" type=\"text\" name=\"hue-bridge-ip\" placeholder=\"192.168.0.*\">";
      echo "<button type=\"submit\">Submit</button>";
      echo "</fieldset>";
      echo "</form>";
   else {
      // Path to hue api
      $hue_http_begin = 'http://'.$hue_bridge_ip.'/api';
      // Create user "eedomushue"
      // Notice: username contains at least 10 characters
      $jsonResponse = httpQuery($hue_http_begin, 'POST', "{\"devicetype\":\"domotique\"}");
      //var_dump($step, $jsonResponse);
      $jsonResponse = substr( $jsonResponse , 1 , -1 );
      // From JSON to XML format
      $xmlResponse = jsonToXML($jsonResponse);
      // Search useful info thanks to XPATH and print
      $error = null;
      $success = null;
      if($step == 1)
         $error = xpath($xmlResponse, "/root/error/description");
      else if($step == 2)
         $success = xpath($xmlResponse, "/root/success/username");
         if ($success == '') // TICKET #76805
         else
        $hue_username = $success;
      if($error === "link button not pressed") {
         $url_to_call = "http://localhost/script/?exec=$exec&step=2&hue-bridge-ip=$hue_bridge_ip&user_name=$hue_username";
            $url_to_call .= "&controller_id=$hue_controller_id";
         // The bridge central button needs to be pressed
         echo "<form>";
         echo "<fieldset>";
         echo "<input type=\"hidden\"  name=\"url\"  value=\"$url_to_call\">";
         echo "<label>Please press the button on the bridge and confirm.</label>";
         echo "<button type=\"submit\">Confirm</button>";
         echo "</fieldset>";
         echo "</form>";
      else if($success == $hue_username) {
         // The user has been created successfully
         // Message to display
         echo "<p>";
         echo "User successfully created or already exists.<br/>";
         echo "The HUE bridge is ready and accepts user \"$hue_username\".<br/>";
         echo "You can now use \"$hue_username\" to control your lights!<br/>";
         echo "Please see the official hue documentation at: ";
         echo "<a href=\"http://developers.meethue.com/\">http://developers.meethue.com/</a>";
         echo "</p>";
         // List available lamps
         echo "<p>Here is a list of the available lamps with their id:</p>";
         echo "<ul>";
         // Get lamp list
         $hue_http_begin = 'http://'.$hue_bridge_ip.'/api/'.$hue_username.'/lights';
         $jsonResponse = httpQuery($hue_http_begin);
         $json = sdk_json_decode($jsonResponse);
         foreach($json as $lamp_id => $lamp) {
            echo "<li>Id : ".$lamp_id.", Name : ".$lamp['name']."</li>";
         echo "</ul>";
         echo "<br><p>Here is a list of the available groups with their id:</p>";
         echo "<ul>";
         // Get group list
         $hue_http_begin = 'http://'.$hue_bridge_ip.'/api/'.$hue_username.'/groups';
         foreach($json as $group_id => $group) {
            echo "<li>Id : ".$group_id.", Name : ".$group['name']."</li>";
         echo "</ul>";
      else {
         // Unknown state or error
         // Button provided to try again
         $url_to_call = "http://localhost/script/?exec=$exec&step=1&hue-bridge-ip=$hue_bridge_ip&user_name=$hue_username";
         echo "<p>An error occured. Please try again. [$error]</p>";
         echo "<form>";
         echo "<fieldset>";
         echo "<button type=\"submit\">Try again</button>";
         echo "</fieldset>";
         echo "</form>";
</section>
</body>
</html>
Retour vers The eedomus box
