Automating Home Ventilation
Messagepar Horia » 28 Oct 2016 13:50
If you are closer to the Alps as I am, you may feel the need for this over the winters for a healthy leaving and cost of heating...
And like me with a home where centralized ventilation was not part of the initial building you may be looking for a solution.
I couldn't find a better one than this, meanwhile is quite decent installation wise and integration wise by Z-Wave.
https://www.google.com/url?sa=t&rct=j&q ... vwa8kzWRjg
They have presence across EU, including France, and they have a model WIFI capable with an iOS app hence hope for an HTTP API.
I engaged with the Swiss office trying to make this a reality in the home, either way, the Aerotec Z-wave or the AeroTube https://www.google.com/url?sa=t&rct=j&q ... JgsYm1XaMg which I see it adds heat recovering maybe HTTP API...
Anybody in France interested and willing to support the request to eedomus to integrate. Otherwise, any better solution you have thought?
Yours, Horia
Maison avec eedomus+, 200 dispositifs(60 en zwave/+, 10 en RFXcom, 5 cameras, les restes virtuel), automatisation éclairage, sécurité maison, environnement, access, chauffage, notifications, agenda.
Horia
Re: Automating Home Ventilation
Messagepar Horia » 04 Nov 2016 17:10
Just an update about my plans here:
- I am planning to use the eedomus CO2 readings from the Netmo sensors as inputs
- Build new rules for ventilation based on CO2 thresholds, presence....
- Deploy probably systems from Siegenia, that have heat recovery and can be relay/plug activated (some have IR controll (I'll probably add one of the IR controller options supported by eeDomus)).
In summary, I dropped the idea for Z-wave control for Aeropac while I think the heat recovery is a lot more important than seamless integration.
Horia
Horia
