Intégration Eedomus -> Node-RED
Re: Intégration Eedomus -> Node-RED
Messagepar soundfab » 29 Déc 2021 13:00
Capture d’écran 2021-12-29 à 12.57.35.png (152.7 Kio) Consulté 38214 fois
voici mon fichier de conf Node-Red sous home assistant.
Mon Home assistant est déplié sur une virtual Box sous Mac OS.
soundfab
Messagepar KikiFUNstyle » 30 Déc 2021 11:47
Il y a une instruction qui fonctionnait AVANT mais plus maintenant
[LAST_VALUE PERIPH_ID=[RAW_VALUE]]
Ce code était censé récupéré la dernière valeur du periph id indiqué dans la valeur brute mais cela ne fonctionne plus :'(
Du coup coté actionneur http :
Valeur brute = 1040004
URL = http://[IP_NODE_RED]:1880/endpoint
Type = GET
Paramètres = /pushEedomus?periphId=[RAW_VALUE]&value=[LAST_VALUE PERIPH_ID=1040004]
Et dans node red de ton home assistant import ce flow :
[{"id":"ccf6ca07f83388f3","type":"group","z":"2460c5f.5cc0b3a","name":"Exemple de endpoint /pushEedomus","style":{"label":true},"nodes":["9dfea1908eaea33f","21915d7b760e6488","654d12b5ba14bfc8","f98166a252a11383","c4335d229eacabcb"],"x":94,"y":379,"w":612,"h":202,"info":"# Permet de récupérer 2 valeurs :\n## periphId / value\n\nexemple :\nhttp://192.168.0.24:1880/endpoint/pushEedomus?periphId=12345&value=98765\n\nRécupère le periphId=12345\net la value=98765"},{"id":"9dfea1908eaea33f","type":"debug","z":"2460c5f.5cc0b3a","g":"ccf6ca07f83388f3","name":"periphid","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload.periphId","targetType":"msg","statusVal":"","statusType":"auto","x":540,"y":500,"wires":[]},{"id":"21915d7b760e6488","type":"http in","z":"2460c5f.5cc0b3a","g":"ccf6ca07f83388f3","name":"récupérer humidité salle de bain","url":"/pushEedomus","method":"get","upload":false,"swaggerDoc":"","x":250,"y":500,"wires":[["9dfea1908eaea33f","f98166a252a11383","c4335d229eacabcb"]]},{"id":"654d12b5ba14bfc8","type":"http response","z":"2460c5f.5cc0b3a","g":"ccf6ca07f83388f3","name":"","statusCode":"","headers":{},"x":490,"y":420,"wires":[]},{"id":"f98166a252a11383","type":"template","z":"2460c5f.5cc0b3a","g":"ccf6ca07f83388f3","name":"","field":"payload","fieldType":"msg","format":"json","syntax":"mustache","template":"{\n    \"success\": 1,\n    \"body\": {\n      \"periph\": \"{{payload.periphId}}\",\n      \"value\": \"{{payload.value}}\"\n    }\n}","output":"json","x":320,"y":420,"wires":[["654d12b5ba14bfc8"]]},{"id":"c4335d229eacabcb","type":"debug","z":"2460c5f.5cc0b3a","g":"ccf6ca07f83388f3","name":"value of periphId","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload.value","targetType":"msg","statusVal":"","statusType":"auto","x":570,"y":540,"wires":[]}]
[Store] Shelly
KikiFUNstyle
Messagepar soundfab » 30 Déc 2021 22:23
Merci beaucoup !! ca marche super bien !! du coup pour mettre a jour régulièrement tu fais une règle sur eedomus ?
soundfab
Messagepar KikiFUNstyle » 30 Déc 2021 22:48
soundfab a écrit:Merci beaucoup !! ca marche super bien !! du coup pour mettre a jour régulièrement tu fais une règle sur eedomus ?
Je fais une règle Eedomus qui dit :
Critères : capteur d'humidité change de valeur
Action : pushEedomus
pour éviter de surcharger la box et de renvoyer que quand la valeur change.
[Store] Shelly
KikiFUNstyle
Messagepar Michteedo » 06 Jan 2022 07:12
voila, j'ai un peu avancer, enfin je pense; j'arrive a récupérer des valeurs de mon IPX ou autre. Et je commande mes relais aussi.
Je suis ce fil et je voulais envoyer la valeur(température) d'un capteur Zwave; j'ai copié l'exemple du debut et no good.....pas de message d'erreur, mais rien dans le debug.
Faut il laisser ceci (/pushEedomus )dans le premier nœud a gauche?
Bien entendu j'ai modifier la valeur brute dans le switch
Merci d avance MI.
PS. Si je tape url et com. dans la ligne de commande du navigateur = 404: Not Found
Es ce grave Doc? lol
Michteedo
Messagepar KikiFUNstyle » 06 Jan 2022 09:56
Regarde cet exemple viewtopic.php?f=12&t=10587&p=102403#p102297
car celui du début ne fonctionne plus.
N'hésite pas à envoyer des capture d'écran et expliquer ce que tu souhaites faire.
[Store] Shelly
KikiFUNstyle
Messagepar Michteedo » 06 Jan 2022 10:42
Merci mais désolé, no good ....
Je voudrais récupérer des valeurs de sonde Zwave et Oregon aussi pour les envoyer vers Node-red.
MI
Capture d’écran (23).png (115.77 Kio) Consulté 38138 fois
Michteedo
Messagepar KikiFUNstyle » 06 Jan 2022 11:28
Tu as suivi ça viewtopic.php?f=12&t=10587#p97594
et compléter avec ça viewtopic.php?f=12&t=10587&start=20#p102297 ?
Une fois que tu as mis en place ceci et que ca ne fonctionne tjs pas.
Dis moi quoi qui ne fonctionne pas et éventuellement qques screenshots
[Store] Shelly
KikiFUNstyle
Messagepar Michteedo » 06 Jan 2022 13:39
Incroyable!
cela ne fonctionne pas, j'ai pourtant, enfin il me semble, fait ce que vous écrivez.
J'ai eu cette erreur a un moment mais plus maintenant.
Capture d’écran (24).png (134.3 Kio) Consulté 38134 fois
Michteedo
Messagepar KikiFUNstyle » 06 Jan 2022 14:22
Montre moi les détails de ton actionneur HTTP Via node red
ainsi que du coté de node red les nodes que tu as mis avec leur conf stp.
[Store] Shelly
KikiFUNstyle
Messagepar Michteedo » 06 Jan 2022 14:33
voici
Capture d’écran (27).png (162.53 Kio) Consulté 38132 fois
Capture d’écran (26).png (175.77 Kio) Consulté 38132 fois
Capture d’écran (25).png (177.1 Kio) Consulté 38132 fois
Michteedo
Messagepar Michteedo » 06 Jan 2022 14:34
Du coté de node red j'ai importé le Json,
Puis je vous tel?
Michteedo
Messagepar KikiFUNstyle » 06 Jan 2022 16:19
Alors déjà sur le 1er screenshot ce n'est pas bon, il faut donc mettre
/pushEedomus?periphId=[RAW_VALUE]&value=[LAST_VALUE_PERIPH_ID=551133]
Quel est l'adresse de votre node red ? Je vois que vous avez mis http://192.168.1.22:8123/endpoint -> cela ressemble à un node red sur home assistant ... est-ce le cas ? Si il est sur home assistant il faut mettre http://192.168.1.22:1880/endpoint dans [VAR1]
ensuite si vous faite dans un navigateur
http://[IP_NodeRED]/pushEedomus?periphId=12345&value=11111
vous devez avoir (normalement) une réponse en json
[Store] Shelly
KikiFUNstyle
Messagepar Michteedo » 06 Jan 2022 16:48
yes merci, j'ai effectivement HA...
je viens de lancer la ligne de commande et good , very good
http://192.168.1.22:1880/endpoint/pushE ... alue=11111
je poursuis MI merci
Ca maaarrche
Capture d’écran (28).png (163.6 Kio) Consulté 38130 fois
Michteedo
Messagepar KikiFUNstyle » 06 Jan 2022 16:54
Youpi \o/
[Store] Shelly
KikiFUNstyle
Messagepar Michteedo » 06 Jan 2022 16:56
Par contre deux capteurs sur le même actionneur; j'en ai un qui ne fonctionne.....je penses qu il doit falloir ajuster le payload...
Michteedo
Messagepar KikiFUNstyle » 06 Jan 2022 17:10
Il faut mettre
/pushEedomus?periphId=[RAW_VALUE]&value=[LAST_VALUE_PERIPH_ID=<ID_DU_PERIPHERIQUE_LE_MEME_QUE_DANS_VALEUR_BRUTE>]
[Store] Shelly
KikiFUNstyle
Messagepar Michteedo » 06 Jan 2022 17:26
ok merci, apres il faut les aiguiller en fonction de leur adresse ID?
Je vois un exemple avec un switch
Michteedo
Messagepar KikiFUNstyle » 06 Jan 2022 17:29
Michteedo a écrit:ok merci, apres il faut les aiguiller en fonction de leur adresse ID?
Oui en fait tu dis à Eedomus d'aller chopper la dernière valeur du périph id
[Store] Shelly
KikiFUNstyle
Messagepar Michteedo » 06 Jan 2022 17:55
Génial merci, voila ce que j'ai fait.
Comment s'appelle se cadre et comment le crée modifier ou l'enlever?
Capture d’écran (29).png (177.21 Kio) Consulté 38133 fois
Michteedo
